Normal Topic DestinationAnchorChanged (Read 2858 times)
Plamen Boev
Aug 4th, 2014 at 3:21pm
when a diagram link changes it's destination anchor AND it's destination node at the same time and the DestinationAnchorChanged event rises - the e.Link.Destination of the link still points to the Destination node BEFORE the anchor has been changed and I can't find any other way to get the new Destination node at this moment. We are syncing the diagram changes with a database and handling this event in the database the id of the previous node is being saved.
Other than that in 1 out of 10 cases of a link changing the destination node the  DestinationAnchorChanged event DOES NOT raise. I could not find out why.
Re: DestinationAnchorChanged
Reply #1 - Aug 4th, 2014 at 4:11pm
This event is raised only if the DestinationAnchor value actually changes, and since the value is an integer index, it won't fire if you move to a point of a different node with the same anchor index. For better results handle LinkModified, then both the origin/destination node and anchor values should be up to date:
private void diagram_LinkModified(object sender, LinkEventArgs e)
	if (e.AdjustmentHandle == 0)
		// first point moved
		Debug.WriteLine(e.Link.OriginAnchor);
	if (e.AdjustmentHandle == e.Link.ControlPoints.Count - 1)
		// last point moved
		Debug.WriteLine(e.Link.DestinationAnchor);
Plamen Boev
Reply #2 - Aug 4th, 2014 at 8:35pm
Thank you, that solved the problem!
