Normal Topic Vertical text length problem (Read 1622 times)
mihai
Aug 7th, 2014 at 2:37pm
I have a shape node with size 50x500, and its text rotated (TextRotationAngle) to 270 degrees. The problem is that the text is truncated as if it had to fit the length of 50, not 500. What can be done about it?
-Mihai
Re: Vertical text length problem
Reply #1 - Aug 7th, 2014 at 6:25pm
Hi Mihai,
Try also setting node.PolygonalTextLayout = true;
mihai
Reply #2 - Aug 7th, 2014 at 7:16pm
That did the trick, thanks Stoyan!
