Normal Topic Rotation questions (Read 2324 times)
-= E W O U D =-
Rotation questions
Aug 28th, 2014 at 12:53pm
1. Is it possible to have a ShapeNode rotate around another point than it's center?
2. Is it possible to have a group of nodes rotate around a common center?
Thank you,
Ewoud
Re: Rotation questions
Reply #1 - Aug 28th, 2014 at 3:17pm
That's not supported out of the box. You could probably implement it by overriding DiagramNode.Draw method to apply a different transform before calling DrawLocal. Current Draw code looks like this:
public override void Draw(IGraphics graphics, RenderOptions options)
    GraphicsState state = graphics.Save();
    RectangleF b = GetBounds();
    graphics.TranslateTransform(b.X, b.Y);
    if (GetRotationAngle() != 0)
        Point center = GetLocalCenter();
        graphics.TranslateTransform(center.X, center.Y);
        graphics.RotateTransform(GetRotationAngle());
        graphics.TranslateTransform(-center.X, -center.Y);
    DrawLocal(graphics, options);
    graphics.Restore(state);
    DrawManipulators(graphics, false, false);
    if (ShouldRenderAnchors(options))
        DrawAnchors(graphics);
You'd also have to override additional methods such as DrawHandles and GetRotatedBounds.
You could set the group's FollowMasterRotation property to make the children rotate around the parent node's center.
-= E W O U D =-
Reply #2 - Aug 29th, 2014 at 11:06am
Thank you for the answer.
I could probably add a temporary node at the desired rotation center (when none of the exiting nodes are), create a temporary group (with the (temporary) node as the 'master'), set FollowMasterRotation on the group, rotate and remove all temporary constructs.
This would allow me to rotate any node or group of nodes around an arbitrary point. Correct?
Reply #3 - Aug 29th, 2014 at 2:50pm
Yes, that will work. Creating and removing temporary nodes will mess up the undo history though if you keep undo enabled. You might have to filter out undo records from ActionRecording events in such case.
