Normal Topic Scrollbar behaviour question (Read 1397 times)
-= E W O U D =-
Sep 9th, 2014 at 11:33am
Currently scrollbars correspond to the diagram bounds. For example they appear when the bounds are outside of the view.
Is it possible to make the scrollbars correspond to the bounds of all content in the diagram (e.g also for items outside the diagram bounds)?
Thank you,
Ewoud
Re: Scrollbar behaviour question
Reply #1 - Sep 9th, 2014 at 11:57am
It's possible only by assigning a larger rectangle to diagram.Bounds. You could either enable AutoResize to grow Bounds automatically when users draw interactively, or call the ResizeToFitItems method to set large enough rectangle to fit items added from code-behind.
