Normal Topic Selection Time Unit (Read 4532 times)
SGS Software
Selection Time Unit
Sep 23rd, 2014 at 8:53am
how can I set a time unit for the selection to make
the user select only full day (or half day), avoiding to
select also hours and minutes?
The same time unit must be obviously kept during the appointment move o lenght changing..
Thanks in advance
Re: Selection Time Unit
Reply #1 - Sep 23rd, 2014 at 11:44am
Which view are you using?
SGS Software
Reply #2 - Sep 23rd, 2014 at 1:06pm
Meppy wrote on Sep 23rd, 2014 at 11:44am:
Sorry, I forgot to specify the view: I am using ResourceView mode.
Reply #3 - Sep 23rd, 2014 at 1:48pm
You can manually enforce full-day selection by handling the Changed event of the Selection class and adjusting the start and end times of the current selection. The following sample illustrates how:
https://mindfusion.eu/_samples/_sample_ResourceViewDescreteSelection.zip
Items are automatically aligned when modified according to the unit specified by the SnapUnit and SnapUnitCount properties of the Calendar.ResourceViewSettings object. The default values (Day and 1 respectively) indicate that items are aligned to the nearest day. To align items to half day you need to set SnapUnit and SnapUnitCount to Hour and 12 respectively:
calendar1.ResourceViewSettings.SnapUnit = TimeUnit.Hour;
calendar1.ResourceViewSettings.SnapUnitCount = 12;
Let me know if this helps.
SGS Software
Reply #4 - Sep 24th, 2014 at 5:00pm
Meppy wrote on Sep 23rd, 2014 at 1:48pm:
Thanks Meppy,
this is what I exactly was looking for!!!
