Normal Topic Horizontal scrollbar (Read 1705 times)
Plamen Boev
Sep 29th, 2014 at 4:46pm
I need to show the horizontal scroll bar of the diagram. It only shows the vertical one no matter that it's contents is larger to the right and is not visible.
I have set:
DiagramView1.ShowScrollbars = True
DiagramView1.ScrollBarProvider.CreateHorizontalScrollBar()
DiagramView1.ScrollBarProvider.CreateVerticalScrollBar()
What do I do wrong?
Re: Horizontal scrollbar
Reply #1 - Sep 30th, 2014 at 7:09am
ScrollBarProvider's methods are called automatically by DiagramView, and the horizontal scrollbar will get hidden if diagram.Bounds.Width pixel value is smaller than DiagramView.Width. If you create nodes programmatically and place them outside of diagram.Bounds, call diagram.ResizeToFitItems or set diagram.Bounds = diagram.GetContentBounds in the end. Set DiagramView.AutoResize to make the control grow automatically while users draw items interactively.
Plamen Boev
Reply #2 - Oct 1st, 2014 at 10:44am
Thank you, it works fine.
