Normal Topic LineChart shows x value of the point as 0 when XAxisSettings.DataFormat = Auto (Read 3978 times)
marina
Nov 4th, 2014 at 11:41am
Once the this.lineChart.XAxisSettings.DataFormat  property is set to "Auto" (default value), there is a weird behavior I observe:
In case the x value of the point is fracture, it gets zero in the chart preview.
See attachment for example:
In both cases the following is chosen:
this.lineChart.XData = new MindFusion.Charting.SeriesCollection("5.3");
this.lineChart.YData = new MindFusion.Charting.SeriesCollection("5");
Thanks in advance,
Marina
Re: LineChart shows x value of the point as 0 when XAxisSettings.DataFormat = Auto
Reply #1 - Nov 4th, 2014 at 12:02pm
The control manages to parse 5.3 as a date and displays it at the beginning of an auto-calculated interval, unless you also set StartDateTime and EndDateTime properties. If you don't need to display dates, keep DataFormat set to Number.
marina
Reply #2 - Nov 4th, 2014 at 1:17pm
It helped,
thank you.
