Normal Topic "Cut" & "Paste" doesn't work (Read 1408 times)
Ton Trommelen
Nov 5th, 2014 at 2:42pm
I'm using Mindfusion Diagramming for Winforms v5.3.5 and I'm having the following problem;
when I "Cut" nodes from a diagram they are not pasted when I give the paste command.
So "Copy" & "Paste" works but not "Cut" & "Paste".
What can this be?
Thanks for the help?
BR, Ton.
Re: "Cut" & "Paste" doesn't work
Reply #1 - Nov 6th, 2014 at 8:50am
CutToClipboard just calls CopyToClipboard and deletes the items, so there's no reason cut to fail if copying works. Check if you are not placing something else in the clipboard in response to NodeDeleted or ActionRecorded events, that would erase the diagram data. Alternative check if you are not removing the items from NodePasted event handler.
