Normal Topic DiagramView is missing the SetZoomFactor method (Read 2109 times)
bogdip
Nov 12th, 2014 at 3:14pm
Hi Stoyan,
We'd like to zoom the diagram by mouse wheel and take the mouse position as a pivot for the zooming. The diagram's method 'SetZoomFactor(double zoomFactor, Point pivotPoint)' suits our needs but unfortunately we can't use it as the diagram is placed inside a DiagramView so any zooming must be done on DiagramView level.
I've noticed in the last patches you've added more zoom methods in the DiagramView, but this one is still missing.
Do you have in plan to add it too or is there a workaround for this ?
Bogdan
Re: DiagramView is missing the SetZoomFactor method
Reply #1 - Nov 13th, 2014 at 9:48am
Now it's available for DiagramView too:
https://mindfusion.eu/_beta/wpfdiag.3.2.zip
private void OnPreviewMouseWheel(object sender, MouseWheelEventArgs e)
	var view = sender as DiagramView;
	if (view != null)
		view.SetZoomFactor(
			view.ZoomFactor + e.Delta / 20.0,
			view.ClientToDoc(e.GetPosition(view)));
		e.Handled = true;
bogdip
Reply #2 - Nov 14th, 2014 at 2:34pm
Thanks much!
