Normal Topic Moving the ContainerNode caption bar (Read 1751 times)
Sim
Nov 19th, 2014 at 10:29am
I am trying to create a BPMN lane element using a ContainerNode. By default, the caption bar is shown at the top of the ContainerNode. However, I want to show the caption bar at the left of the ContainerNode, is this possible?
I have added an example of the current ContainerNode as well as the prefered ContainerNode as an attachment. The prefered layout of the ContainerNode could be seen as a horizontal layout while the default layout is could be seen as a vertical layout.
With kind regards,
Simon
Re: Moving the ContainerNode caption bar
Reply #1 - Nov 19th, 2014 at 12:06pm
Try setting container.RotationAngle = 270;
Sim
Reply #2 - Nov 19th, 2014 at 12:42pm
Stoyo wrote on Nov 19th, 2014 at 12:06pm:
Thank you! This has solved my problem.
With kind regards,
Simon
