Normal Topic MindFusion ASP.NET Pack 2014.R3 (Read 8046 times)
Nov 27th, 2014 at 10:47am
We have released MindFusion ASP.NET Pack 2014.R3. It contains the following new features:
MindFusion.Diagramming for WebForms
Zoom control
(not available in JavaApplet mode)
The ZoomControl class lets users change interactively the current zoom level and scroll position of a DiagramView. To set it up, add a ZoomControl element to the page and set the control's TargetId property to the id of a DiagramView. Set the ZoomStep and ScrollStep properties to specify the amount added to diagram's zoom level or scroll position by ZoomControl's buttons. You can customize the control's appearance by setting properties such as Fill, BorderColor, CornerRadius and TickPosition.
Canvas mode improvements
  • The ShadowsStyle property is now supported in Canvas mode.
  • Number of link segments can now be set from client-side scripts by calling the setSegmentCount method.
  • The BackgroundImageAlign property is now supported in Canvas mode.
  • The TextPadding property of items is now supported in Canvas mode.
  • Nodes of all classes can be rotated.
  • Fixed a bug where the Alpha value of colors was lost after post-back.
Improved arrowhead rendering
  • Arrowheads are rendered as a single path when possible and several arrowhead Shape definitions has been changed to implement mitered joints when HeadPen is set to a thick pen.
  • The point where end segments connect to arrowheads can be specified via the LinkSegmentInset property of shapes. Shape definitions from the ArrowHeads class set it to suitable default value. This allows using transparent or semi-transparent brushes without seeing the link line drawn behind arrowheads.
  • Arrowhead shadows are no longer filled if the link's EffectiveBrush is null or fully transparent.
  • VisioExporter export speed has been improved greatly for large diagrams.
  • For consistence with MindFusion libraries for other platforms, BackBrush in default diagram style has been changed to white brush.
  • Improved DiagramLink rendering speed.
  • Multiple-resize of rotated nodes fixed to apply same offsets in nodes' local coordinate system.
  • The Brush property of LinkLabel class lets you set background color for link labels.
  • The ChangeUnit method sets a new MeasureUnit and rescales the coordinates of diagram items to keep them the same size.
MindFusion.Mapping for WebForms
MindFusion.Mapping for WebForms comprises a .NET server control and a class library that provides your application with great features for loading, customizing and displaying any type of regional, national or world map. Easy to integrate and program, this control gives you the power to build the perfect map according to your needs with minimal time and efforts from your side. You can:
  • add labels to map elements
  • access database data associated with map elements
  • choose the color scheme
  • set decorative elements like images, icons etc.
Map data can be loaded from the popular ESRI Shapefile format and you have at your disposal an impressive variety of *.shp files, which give you valuable data for any country in the world as well for selected cities, rivers, roads and other geographic objects. Data for the attributes of map elements can be loaded from a DBF file associated with each map. The control supports multiple layers so you can show several maps in a single view.
MindFusion.UI for WebForms
Slider control
The Slider control represents a range slider, which can be used to specify a numeric value constrained between a minimum and maximum.
https://mindfusion.eu/WebFormsTrial.zip
