Normal Topic Side effects caused by setPen?? (Read 2520 times)
RickSalut
Dec 10th, 2014 at 7:06pm
I'm quite new to jDiagram and I'm experiencing an issue that I cannot find any information on this website so I'm trying the forum.
When I programmatically change the Pen attributes (color, width, etc...) of a ShapeNode, it sometimes (not always) changes the Pen of the attached links as well.
Do any of you guys have had the same problem before?
Thank you.
Re: Side effects caused by setPen??
Reply #1 - Dec 10th, 2014 at 8:02pm
Are you assigning a new Pen instance to the node? setPen does not clone its argument, so I imagine you might see similar problems if you use some shared / static Pen object, change its attributes and assign it to nodes and links. Then you'd end up with items drawing themselves with same pen.
If it's a different problem, please attach a test Java class demonstrating it.
