Normal Topic Standard forms not working with DB change. (Read 4249 times)
TRB
Meppy knows all!!
Jan 15th, 2015 at 1:46am
Hi, I have added code to my program allowing the user to select the database they wish to use which changes the connection string. This works well however when I try to open an appointment the standard appointment form fails to show. Do you have any ideas as to what is happening? It seems to simply exit the sub on "CurrentAppForm = new AppointmentForm(calendar1.schedule)". Undecided If I change the database back to the original one all forms open as expected...
TRB
Re: Standard forms not working with DB change.
Reply #1 - Jan 15th, 2015 at 3:35pm
Can you save the schedule, which is used to initialize the form, as an XML file and send it to me? Also, what version of the control are you using?
TRB
Meppy knows all!!
Reply #2 - Jan 16th, 2015 at 11:53am
Unfortunately Meppy, I do not actually know how the SaveToXML Method works. Embarrassed A bit embarrassing I know.  Where does the XML document get the structure? When I create a New XML Document and then use SaveToXML(NewXMLDoc) I get the object reference not set to an instance of an object error. Sorry.  Undecided
TRB
Reply #3 - Jan 16th, 2015 at 1:25pm
You can save the schedule by calling Schedule.SaveTo(path, ContentType.Xml). Call this method before showing the appointment form and send me the resulting XML file. If this raises an exception, it is probably a bug and I will appreciate it if you post the stack trace.
