Normal Topic Diagramming for JavaScript, V2.3 (Read 2270 times)
Feb 19th, 2015 at 9:23am
We have released version 2.3 of MindFusion.Diagramming for JavaScript. It contains the following new features:
Styled text in nodes
The ShapeNode.EnableStyledText property allows using HTML-like formatting tags to apply various attributes to the node's text. At this time the component supports the following formatting tags:
  • <b> specifies bold text
  • <i> specifies italic text
  • <u> specifies underlined text
  • <color=value> specifies text color
  • <br /> specifies line break
Text rendering improvements
  • General text rendering quality improved. The component removes scale transformations applied for MeasureUnit and ZoomFactor before drawing text on the canvas, and instead specifies a scaled font size, which helps improve text appearance in Firefox and older versions of Chrome.
  • Now items' text can be drawn underlined. To enable this, set the underline attribute of the Font class.
  • Font styles can be specified via Style instance by calling its setFontStyle() method with a combination of MindFusion.Drawing.FontStyle enumeration members (Bold, Italic, Underline).
  • Items can be drawn using dashed lines in browsers that support the setLineDash function. To enable this, set the StrokeDashStyle property of DiagramItem or Style to a member of the MindFusion.Drawing.DashStyle enumeration (Solid, Dash, Dot, DashDot, DashDotDot).
  • TreeLayout supports organizational charts with assistant nodes as in Microsoft Office diagrams. To mark nodes as assistants, set node.getLayoutTraits().treeLayoutAssistant to a member of the MindFusion.Graphs.AssistantType enumeration (Normal, Left, Right). Set treeLayout.enableAssistants = true; to arrange assistant nodes in a separate branch between the main node levels.
  • Specify if separate connected components of a graph should be arranged horizontally or vertically relatively to each other by setting the multipleGraphsPlacement attribute of layout classes.
  • The type of LinkLabel.Margin property has been changed from number to Thickness, letting you specify different margin sizes at each side of the label.
