Normal Topic Licensing of FlowChart.NET received through NuGet (Read 2962 times)
stefski
May 11th, 2015 at 11:18am
Hi Stoyan,
I have now upgraded our FlowChart.NET component from 5.7 to 6.3.2.
We noticed that you are now making the component available via NuGet, and we would like to utilize this channel of deployment. How do we enter our license information to enable the full version on these packages? At the moment the diagram component will begin displaying "trial version" on the canvas and as node labels after a while. Smiley
Kind regards
Steffen Skov
OLGA Application Architect
Schlumberger Information Solutions AS
Re: Licensing of FlowChart.NET received through NuGet
Reply #1 - May 11th, 2015 at 5:47pm
Hi Steffen,
You should have received a license key string with your order confirmation e-mail. You should also have the key listed on your account page at clients' area on our site (if you have registered there). Copy and paste that key into DiagramView.LicenseKey property in form editor, or alternatively call MindFusion.Licensing.LicenseManager.AddLicense(the key) from your application startup code.
The control no longer looks for design-time license keys in the registry - now you don't have to run full installation on every build or development system but just deploy the dll files.
stefski
Reply #2 - May 12th, 2015 at 8:30am
Thank you Stoyan for your quick response. We will follow this description. Smiley
Kind regards
Steffen Skov
