Normal Topic How to add header, footer, legend to diagram? (Read 2485 times)
David Adams
May 29th, 2015 at 7:44am
I have a requirement to add a header, footer, and legend to diagrams (swim lanes layout and tree map layout) and I was wondering if there are any built-in features I could use to achieve this, or if anyone has done this before and can point me in the right direction.
DA
Re: How to add header, footer, legend to diagram?
Reply #1 - May 29th, 2015 at 8:53am
If you don't need these elements to scroll together with diagram contents, you could implement them in outer Xaml code:
<StackPanel>
  <header here />
  <ScrollViewer>
    <Diagram/>
  </ScrollViewer>
  <footer here />
</StackPanel>
If they should scroll, you could implement them using nodes inside the diagram (e.g. TableNode or TemplatedNode), with Locked and IgnoreLayout properties set to true.
David Adams
Reply #2 - Jun 2nd, 2015 at 1:02pm
Thanks Stoyan.
Using Locked and IgnoreLayout properties set to true is the solution I need and that works for the diagram on screen.
I also need to export the diagram to PDF and I find that sometimes those elements are not included in the PDF. Any suggestions for resolving that?
DA
Reply #3 - Jun 3rd, 2015 at 10:53am
This will work for PDF only if you export to a single page using PdfExporter.PageSize = DiagramSize. There's no way to make same header and legend nodes appear on every page if exporting to multiple pages. You might try paginating the diagram yourself, creating a DiagramPage for each A4-sized part, adding header and legend nodes to each page, and exporting using Export(DiagramDocument) overload. For next release we could implement some method to let you adorn the WPF Visual objects generated by exporter for each page with your own graphics for headers, legends, watermarks, etc.
