Normal Topic MindFusion.Scheduling for Java Swing, v1.2 (Read 2751 times)
Jun 4th, 2015 at 3:03pm
We have released version 1.2 of MindFusion.Scheduling for Java Swing. The new version includes:
Licensing
There is no separate trial build of the control anymore. Instead, use the setLicenseKey method of the AwtCalendar control to disable the component's evaluation mode and stop displaying trial messages. License key strings are listed on the Keys & Downloads page at MindFusion's customer portal.
Interactive Recurrence Rescheduling
Recurrences can be rescheduled interactively by holding down the key specified by RescheduleRecurrenceKey while dragging a recurrent item. The control tries to preserve the current pattern of the recurrence when possible. Otherwise, the recurrence may be modified to accommodate to the new start and end times of the modified item. Interactive rescheduling is not registered in the undo history.
New Theme
A new built-in theme is available in JPlanner - the Light theme. Preview of this theme is available in JPlanner Themes.
New Members
Several new members have been added to the control:
  • The new HScrollBarHeight and VScrollBarWidth properties in the ControlStyle class allow you to modify the size of the scrollbars.
  • The RescheduleRecurrenceKey property in the AwtCalendar class can be used to modify recurrences interactively.
  • The RotateGroupHeaderTexts property in the ListViewSettings class can be used to rotate the resource names in the group headers.
  • GroupHourCount, HourFormat and TimelinePadding added to the TimetableSettings class.
  • Several new CustomDrawElements have been added - ItemEndResizeBand, ItemMoveBand, and ItemStartResizeBand.
  • The new EnableCollisions property can be used to disable item collisions in Resource view.
The component is available for download here:
https://mindfusion.eu/JPlannerTrial.zip
Additional information about the library can be found in the Online Documentation:
http://mindfusion.eu/onlinehelp/jplanner/index.htm
