Normal Topic JDiagram focus handling (Read 7576 times)
Jasef
Jul 23rd, 2015 at 9:42pm
I'm currently having behaviour issues with how focus is handled for overlapping nodes in a diagram.
Scenario (refer to attached image):
I have two nodes that have an overlap. (See 1)
I give focus to node 1 (See 2)
I click in the overlapping area (See star in 2)
Node 2 becomes the new selected node (See 3)
The same applies if you want to create a link between node 1 and a node 3.
It seems to use the z-order.
Can this be changed to prioritize selected nodes.
Cheers,
Jasef.
Re: JDiagram focus handling
Reply #1 - Jul 24th, 2015 at 9:52am
For time being add this to top of getNodeAt(Point2D) and getItemAt(Point2D, boolean, boolean) methods in Diagram:
if (selectionOnTop)
	node = getSelectedNodeAt(point);
	if (node != null)
		return node;
and
DiagramNode getSelectedNodeAt(Point2D point)
	List<DiagramNode> selectedNodes = new ArrayList<DiagramNode>(selection.getNodes());
	java.util.Collections.reverse(selectedNodes);
	for (DiagramNode n : selectedNodes)
		if (n.containsPoint(point) && isItemInteractive(n))
			return n;
	return null;
We might not keep it there for official release but move to hit-testing methods in behavior classes.
Jasef
Reply #2 - Jul 26th, 2015 at 8:08pm
That does the job.
Cheers.
