Normal Topic Can not add any control to a form and save it (Read 1997 times)
CanadaProgrammer
Jul 29th, 2015 at 6:31am
I drag and control from toolbox to add a control to a form such Diagram, DiagramView. But I can not save the form. When I do it I get a error like what attachment shows.
My VS is 2013 Ultimate, OS is Win8 64bit
Re: Can not add any control to a form and save it
Reply #1 - Jul 29th, 2015 at 7:14am
This happens if currently registered Diagramming.WinForms.Design.dll does no match the Diagramming.WinForms.dll used in project, or if VS has loaded two copies of the diagramming.dll. Have you uninstalled your previous version of the control before installing current one? You should still be able to save by resetting Diagram.DefaultShape to its default value so VS does not try to generate assignments for it, and set it later from Load handler.
