Normal Topic Huge resources collection (Read 4595 times)
SGS Software
Sep 15th, 2015 at 3:25pm
Hi, I have a serious problem.
The calendar is getting very slow at the startup with about 1000 resources loaded.
Do you have a solution/workaround for this problem?
Anyway is there a function to get the first and the last visible resources as for the visible dates?
Thank you
Re: Huge resources collection
Reply #1 - Sep 16th, 2015 at 6:51am
We will look into the performance slowdown. There is currently no way to get the first/last visible resource, but we will try to add a method to do this for the next release.
SGS Software
Reply #2 - Sep 16th, 2015 at 6:55am
Meppy wrote on Sep 16th, 2015 at 6:51am:
Thank you Meppy,
I am now working around with a paginate resources loading,
but I think it isn't the right way because I have to hide the vertical bar and handle it with the .net native component
Reply #3 - Sep 16th, 2015 at 12:58pm
Hi again,
We made some improvements to the performance of the Resource view. We also added the two requested methods to the Calendar class - GetFirstVisibleResource and GetLastVisibleResource. A preview version can be downloaded from the link below:
https://mindfusion.eu/_temp/MindFusion.Scheduling.zip
Let me know if this helps.
SGS Software
Reply #4 - Sep 18th, 2015 at 7:20am
Meppy wrote on Sep 16th, 2015 at 12:58pm:
Hi again,
the performance improvements seems to perform better!
Thank you also for the visible resource method!  Smiley
