Normal Topic AnchorPattern lost after load from xml (Read 2118 times)
RunMan
Sep 24th, 2015 at 10:23am
i implement a simple application to build , store and load diagrams. After load a saved diagram, the anchor patterns are lost. All anchor points are in the upper lift edge of the nodes.
What can i do to restore the anchor points?
Thank you
RunMan
Re: AnchorPattern lost after load from xml
Reply #1 - Sep 24th, 2015 at 11:07am
If you use AnchorPattern constructor that takes Id argument, the control will save only the identifier in XML files. It assumes that the pattern is registered by application's startup code and LoadFromXml will only call AnchorPattern.FromId when it sees the pattern's id value. If you want to save and restore everything from the pattern definition, do not specify id when constructing it.
RunMan
Reply #2 - Oct 6th, 2015 at 7:11am
Hi Stoyan,
this helps!
Thank you
RunMan
