Normal Topic Convert diagram in json string (Read 4239 times)
Silvia88
Sep 27th, 2015 at 2:00pm
I have another problem I tried to convert ShapeNode in a json string using the json library but it gave me an exception that ShapeNode contains field with the same name, do you know a way to convert it in a json using or this library or even another one if you know some library that does this?
Re: Convert diagram in json string
Reply #1 - Sep 28th, 2015 at 7:19am
Hi, Which JSON library are you using, and what are the exception's message and stack trace?
Silvia88
Reply #2 - Sep 28th, 2015 at 7:44am
Hi, I used Gson libray and the exception is:
09-28 09:41:25.207  12731-12731/? E/AndroidRuntime﹕ FATAL EXCEPTION: main
Process: com.example.silvia.er, PID: 12731 java.lang.IllegalArgumentException: class com.mindfusion.diagramming.ShapeNode declares multiple JSON fields named a
          at com.google.gson.internal.bind.ReflectiveTypeAdapterFactory.getBoundFields(Reflec
tiveTypeAdapterFactory.java:122)
            at com.google.gson.internal.bind.ReflectiveTypeAdapterFactory.create(ReflectiveType
AdapterFactory.java:72)
            at com.google.gson.Gson.getAdapter(Gson.java:356)
            at com.google.gson.internal.bind.CollectionTypeAdapterFactory.create(CollectionType
AdapterFactory.java:52)
            at com.google.gson.internal.bind.ReflectiveTypeAdapterFactory$1.<init>(ReflectiveTy
peAdapterFactory.java:82)
            at com.google.gson.internal.bind.ReflectiveTypeAdapterFactory.createBoundField(Refl
ectiveTypeAdapterFactory.java:81)
tiveTypeAdapterFactory.java:118)
            at com.google.gson.Gson.toJson(Gson.java:585)
            at com.google.gson.Gson.toJson(Gson.java:572)
            at com.google.gson.Gson.toJson(Gson.java:527)
            at com.example.silvia.er.MainActivity$4$3.onClick(MainActivity.java:267)
            at com.android.internal.app.AlertController$ButtonHandler.handleMessage(AlertContro
ller.java:165)
            at android.os.Handler.dispatchMessage(Handler.java:102)
            at android.os.Looper.loop(Looper.java:145)
            at android.app.ActivityThread.main(ActivityThread.java:6134)
            at java.lang.reflect.Method.invoke(Native Method)
            at java.lang.reflect.Method.invoke(Method.java:372)
            at com.android.internal.os.ZygoteInit$MethodAndArgsCaller.run(ZygoteInit.java:1399)
            at com.android.internal.os.ZygoteInit.main(ZygoteInit.java:1194)
The line which launches this exception is:
errorList += gson.toJson(e, Entity.class)+";";
Reply #3 - Sep 28th, 2015 at 2:03pm
It's not a good idea to use this library directly on diagram's object model for several reasons:
- it serializes private fields through reflection, but they are renamed by our obfuscator so the produced Json won't be very legible.
- apparently it cannot handle inherited private fields having same name as ones in child class.
- "Note that you can not serialize objects with circular references since that will result in infinite recursion" from gson docs, while there are some such references in the diagram model (e.g. link.origin.outLinks[0])
What you could do is create your own data classes, copy item properties to them and then pass them to the serializer:
class ShapeNodeJson
  String text;
  String shape;
  float x;
  // etc
shapeNodeJson.text = shapeNode.getText();
shapeNodeJson.shape = shapeNode.getShape().getId();
shapeNodeJson.x = shapeNode.getBounds().x;
// now serialize shapeNodeJson
Silvia88
Reply #4 - Sep 28th, 2015 at 2:05pm
ok, thank you very much, I'll try it Smiley
