Normal Topic Vertical ruler large ticker position (Read 2572 times)
Kyle Chen
Oct 15th, 2015 at 2:29pm
Hi Stoyan,
It's been a while not upgraded my Diagram library since v4.0.30319 because it runs very well. Hope you're doing great lately!
Here's a minor issue about Diagram ruler - the vertical bar shows the large ticker at 5/8" in inch unit but Horz. at 1/2" position. Please see attachment.
Is there any work around for this? Or has this been fixed in latest library so I have to purchase an upgrade? Cheesy
Kyle
« Last Edit: Oct 19th, 2015 at 1:13pm by Kyle Chen »
Re: Vertical ruler large ticker position
Reply #1 - Oct 16th, 2015 at 9:39am
Hi Kyle,
This was fixed in v6.0.4 from August 2013, check if you have access to it from your account page at our customer portal.  The v4.0.30319 number you cite is 'Runtime version', meaning what .NET framework is targeted by the assembly. Check the "Version" attribute instead for diagram's version.
Kyle Chen
Reply #2 - Oct 19th, 2015 at 1:13pm
OK, will upgrade to new version. Thanks Stoyan!
