Normal Topic Export to SVG (Read 7507 times)
Carlos_Rocha
I love Jazz
Export to SVG
Oct 16th, 2015 at 4:51am
Hello Stoyo  Smiley
I would like to save a diagram to memory in SVG format to be able to load it with a different control.
I'm aware of SvgExport, but do I have any option to do this without saving to a file first?
Carlos
Re: Export to SVG
Reply #1 - Oct 16th, 2015 at 9:59am
Hi Carlos,
Currently there's no support for generating SVG without using files. You will have to export a temp file, read it back as a string and delete.
Carlos_Rocha
I love Jazz
Re: Export to SVG
Reply #2 - Oct 19th, 2015 at 3:16am
The SvgExporter recently merged with FlowChartX causes a big crash when I try to call the Export method.
But an old one that I still have on my disk (FcxSvgExport.dll version 1.0.3, from 2007) works fine.
I'll try now to use a named pipe to intercept the writing to a file and redirect it to a memory buffer.
Re: Export to SVG
Reply #3 - Oct 19th, 2015 at 8:27am
Please save and attach the diagram that causes crash.
Carlos_Rocha
I love Jazz
Re: Export to SVG
Reply #4 - Oct 19th, 2015 at 12:00pm
The diagram is saved as string in a db (SQLite) and loaded with LoadFromString.
I attached both the string and the SVG exported with FcxSvgExport.dll
Re: Export to SVG
Reply #5 - Oct 29th, 2015 at 6:33pm
This build should fix the integrated exporter:
https://mindfusion.eu/_beta/fcx492.zip
Carlos_Rocha
I love Jazz
Re: Export to SVG
Reply #6 - Oct 29th, 2015 at 11:57pm
Yes, it solves it, thank you.
<snif> Still not Pipes allowed, tho </snif>  Sad
