Normal Topic MindFusion.Scheduling for WPF, version 3.4 (Read 2621 times)
Nov 3rd, 2015 at 12:55pm
We have released version 3.4 of MindFusion.Scheduling for WPF. The new version includes:
Interactive Recurrence Rescheduling
Recurrences can be rescheduled interactively by holding down the RescheduleRecurrenceKey while dragging a recurrent item. The control tries to preserve the current pattern of the recurrence when possible. Otherwise, the recurrence may be modified to accommodate to the new start and end times of the modified item. Interactive rescheduling is not registered in the undo history.
New Theme
A new built-in theme is available in MindFusion.Scheduling for WPF - the Light theme. It is available through the ThemeType enumeration.
New Members
Several new properties and events have been added to the control:
  • The RescheduleRecurrenceKey property in the Calendar class can be used to modify recurrences interactively.
  • TickSize added to the ResourceViewSettings class.
  • Calendar.FilterItem event.
The component is available for download here:
https://www.mindfusion.eu/WpfPlannerTrial.zip
The component is also available on Nuget. To install the component, run the following command in the Package Manager Console:
PM> Install-Package MindFusion.Scheduling.Wpf
« Last Edit: Nov 30th, 2020 at 3:08pm by Forum Admin »
