MindFusion.Reporting for WPF 1.4 has been released. It adds the following new features:
Report ParametersParameters can now be added to a report through the new Parameters collection of the Report class. The parameters provide name, description and value and can be of any type, including expression. For more information about parameters, check the Report Parameters topic.
BarcodesMindFusion.Reporting for WPF reports can now display UPC-A, UPC-E, EAN-8, EAN-13, and QR barcodes. The barcodes are represented by the new Barcode report item.
Improved chartsSeveral new properties have been added to the LineChart class to imporive the customization for the plot, grid, legend and axes. The axes settings can be specified through the new XAxisSettings and YAxisSettings properties.
The AxesChart class exposes four new properties, which can be used to specify the intervals displayed by the chart axes. The new properties are XMinValue, XMaxValue, YMinValue, and YMaxValue.
Miscellaneous- Report items can be searched by name through the new FindItem method.
- Fixed an issue with horizontal data ranges.
- Items in data range headers and footers can now bind to the data source of the data range.
- New sample illustrating the Barcode report items.
The component is available for download here:
https://mindfusion.eu/WpfReportingTrial.zipThe component is also available on Nuget. To install the component, run the following command in the
Package Manager Console:
PM> Install-Package MindFusion.Reporting.WpfAdditional information about the library can be found in the Online Documentation:
https://www.mindfusion.eu/onlinehelp/wpfreporter/index.htmEnjoy!
