Normal Topic MindFusion.Reporting for Silverlight 1.4 (Read 2150 times)
Nov 6th, 2015 at 12:41pm
MindFusion.Reporting for Silverlight 1.4 has been released. It adds the following new features:
Report Parameters
Parameters can now be added to a report through the new Parameters collection of the Report class. The parameters provide name, description and value and can be of any type, including expression. For more information about parameters, check the Report Parameters topic.
Barcodes
MindFusion.Reporting for Silverlight reports can now display UPC-A, UPC-E, EAN-8, EAN-13, and QR barcodes. The barcodes are represented by the new Barcode report item.
  • Report items can be searched by name through the new FindItem method.
  • Fixed an issue with horizontal data ranges.
  • Items in data range headers and footers can now bind to the data source of the data range.
  • New sample illustrating the Barcode report items.
The component is available for download here:
https://mindfusion.eu/ReportingLiteTrial.zip
The component is also available on Nuget. To install the component, run the following command in the Package Manager Console:
PM> Install-Package MindFusion.Reporting.Silverlight
Additional information about the library can be found in the Online Documentation:
https://www.mindfusion.eu/onlinehelp/reportinglite/index.htm
« Last Edit: Nov 30th, 2020 at 6:38pm by Forum Admin »
