Normal Topic Node Click (Read 2294 times)
Shah
Node Click
Feb 3rd, 2016 at 2:47am
Hi, I'm new in mindfusion and a little bit confusion on how to select a node try
Dim node =   diagramview1.Diagram.Factory.CreateSvgNode(bounds)
        node.Transparent = True
        node.Locked = locked
Tru with sshapenode also. Also not working. Am I doing it wrong or am i missing something?
Thanks.
Online
Re: Node Click
Reply #1 - Feb 3rd, 2016 at 7:29am
Hello there,
You cannot select nodes when they are locked, you will have to set Locked to false first. If you need selection to work while preventing end-users from modifying a node, set node.EnabledHandles to None. If you need a kind of read-only mode for whole diagram, set the Behavior property to either DoNothing or SelectOnly.
You can select nodes from code-behind by setting their Selected property, or by calling diagram.Selection methods like Add, Toggle, Change.
Shah
Re: Node Click
Reply #2 - Feb 11th, 2016 at 4:53am
Thanks for the reply. Very helpful
