Normal Topic Exporting diagram in pdf (Read 5274 times)
Silvia88
Mar 16th, 2016 at 9:30am
Hi, how can I export a created diagram in pdf format?
Re: Exporting diagram in pdf
Reply #1 - Mar 16th, 2016 at 10:01am
There's no built-in PDF export in the Android library. At this time you could send diagram's XML file to a web server and export it on the server using Mindfusion's Java or .NET libraries.
Silvia88
Reply #2 - Mar 16th, 2016 at 10:17am
But in the documenttation there is this sentence:
A DiagramDocument can be exported to PDF using the new overloads available in the PdfExporter. Other export classes do not support multi-page export at this time, but still can be used to export individual pages via their Export(Diagram) method
what does it mean? Here is the link: http://www.mindfusion.eu/onlinehelp/droiddiagram/index.htm
Reply #3 - Mar 16th, 2016 at 10:32am
I guess someone copied the doc.comment of DiagramDocument class from Java version of the library without checking what it says. There's no PdfExporter available in Android diagram at this time. The sentence is still true though Wink If you export on server side, it's still only PdfExporter that supports multi-page export.
Silvia88
Reply #4 - Mar 16th, 2016 at 10:39am
Ok, thank you very much, is there another way to export it? for example I read SVG format
Reply #5 - Mar 16th, 2016 at 11:07am
It seems Google added native PdfDocument class for PDF generation in API level 19 -
http://developer.android.com/reference/android/graphics/pdf/PdfDocument.html
Try following the example above, replacing the content.draw line with diagram.draw(page.getCanvas());
