Normal Topic Saving WPF Scheduler data into SQL Database (Read 4030 times)
Garry
Apr 7th, 2016 at 5:14am
Hi Meppy, Cool
I am using the latest WPF scheduler control 4.0 from 2016 build. I can see from documentation that there are options to export data into XML, XSLX & PDF.
However i am looking for an option to save data into SQL database. Please let me know how is it possible? Undecided
Regards
Garry
Re: Saving WPF Scheduler data into SQL Database
Reply #1 - Apr 7th, 2016 at 4:55pm
Hi Garry,
Meppy is on a leave so you'll have to do with me for now Roll Eyes There's no built-in SQL export. You could save to a database by iterating over the schedule items and creating corresponding table rows or Entity Framework objects. E.g. this example works with EF -
public Window1()
    InitializeComponent();
    Closing += new System.ComponentModel.CancelEventHandler(Window1_Closing);
    calendar.BeginInit();
    calendar.TimetableSettings.Dates.Clear();
    for (int i = 0; i < 5; i++)
        calendar.TimetableSettings.Dates.Add(
            DateTime.Today + new TimeSpan(i, 0, 0, 0));
    calendar.EndInit();
    foreach (var dbApp in db.Appointments)
        calendar.Schedule.Items.Add(
            new MindFusion.Scheduling.Appointment
                Tag = dbApp,
                Subject = dbApp.Title,
                DescriptionText = dbApp.Description,
                StartTime = dbApp.Start,
                EndTime = dbApp.End
void Window1_Closing(object sender, System.ComponentModel.CancelEventArgs e)
    int autoId = db.Appointments.Any() ?
        db.Appointments.Select(a => a.Id).Max() + 1 : 0;
    foreach (MindFusion.Scheduling.Appointment app in calendar.Schedule.Items)
        var dbApp = (Appointment)app.Tag;
        if (dbApp == null)
            dbApp = db.Appointments.CreateObject();
            dbApp.Id = autoId++;
            db.Appointments.AddObject(dbApp);
        dbApp.Title = app.Subject;
        dbApp.Description = app.DescriptionText;
        dbApp.Start = app.StartTime;
        dbApp.End = app.EndTime;
    db.SaveChanges();
ScheduleEntities db = new ScheduleEntities();
If using full SqlServer you can skip the Id assignment part (I've tested that with Compact edition and it does not support auto-identifiers). Also if you don't care about creating separate records but only saving the full schedule, you could use a MemoryStream and schedule's SaveTo/LoadFrom methods, storing the stream's bytes in a BLOB or TEXT field.
Garry
Reply #2 - Apr 19th, 2016 at 5:09am
Sorry for late response.
I have tested your solution but its giving me a run time exception. Please see the attached screenshot.
