Normal Topic LoadFromStream exception - out of memory (Read 1720 times)
calvin chin
May 11th, 2016 at 4:03am
This function sometimes giving me issue when the stream contains image. It does not happen in all the PC, but it happened on some others.. Wondering what could have cause the problem.
Read the exception stack, seems like when it try to load the image in the stream cause it. Any solution?
Re: LoadFromStream exception - out of memory
Reply #1 - May 11th, 2016 at 7:55am
Please post the stack trace. Does the stream contain only diagram's bytes, or also your application's data?
