Normal Topic Set single key color (Read 3730 times)
Jim
May 20th, 2016 at 7:34pm
Is possible to change background (also hover & pressed background too) color of a single key on the keyboard at runtime?
Also, how to lock to capslock on a shift doubleclick/doublepress?
Re: Set single key color
Reply #1 - May 21st, 2016 at 5:51am
At this time painting keys in distinct colors can be done only through a custom KeyTemplate, for example this paints a red Enter key -
class MyTemplate : KeyTemplate
	public MyTemplate()
		defaultBrush = Background;
	GradientBrush defaultBrush;
	public override void Draw(Graphics g, Key key, Mode mode, Font font)
		if (key.Equals(Key.ENTER))
			Background = new GradientBrush(
				new List<Color> { Color.Red },
				new List<float> { 0f }, 0f);
			base.Draw(g, key, mode, font);
			Background = defaultBrush;
			return;
kb.KeyTemplate = new MyTemplate();
Reply #2 - May 21st, 2016 at 6:05am
One way I can see to enable CapsLocks is calling Key.CAPSLOCK.Send method. There's no Key-DoubleClicked event available, instead you might hadle KeyPressed and check the time to determine if it's a double click -
void OnKeyPressed(object sender, VirtualKeyEventArgs e)
	if (e.Key.Equals(Key.SHIFT))
		if (lastClick != null &&
			DateTime.Now - lastClick.Value < TimeSpan.FromSeconds(0.5))
			Key.CAPSLOCK.Send(true);
		lastClick = DateTime.Now;
