Normal Topic Resizing of Node doesn't resize attached Nodes (Read 1922 times)
Cyrinael
Jul 27th, 2016 at 7:15am
I have several nodes attached to another node n1. If I resize n1, the attached nodes don't resize accordingly. Is there a flag that I have to set, or do I have to implement that behavior in the event handler (probably OnSelectionModifying).
Cyrinael
Cyrinael
Re: Resizing of Node doesn't resize attached Nodes
Reply #1 - Jul 27th, 2016 at 7:41am
I think I have found the issue:
    child.AttachTo(node, AttachToNode.TopLeft);
Is there a way to attach a node in such a way, that the position is not fixed and the size is also resized accordingly?
Cyrinael
Reply #2 - Jul 27th, 2016 at 8:51am
try using this overload -
public void AttachTo (
    DiagramNode node,
    GroupAnchorStyles anchorStyles
The GroupAnchorStyles flags can be combined to specify one or more sides that should resize along with corresponding sides of the master node.
Cyrinael
Reply #3 - Aug 2nd, 2016 at 8:34am
Hello Slavcho,
that solved my problem.
thank you,
Cyrinael
