Normal Topic Diagramming for WPF, V3.4.1 (Read 3134 times)
Aug 22nd, 2016 at 9:14am
We have released version 3.4.1 of WPF Diagram control. It contains the following new features and improvements:
ShapeListBox control
The ShapeListBox control displays a list of Shape icons along with their DisplayName. It lets users drag-and-drop a Shape to the diagram's canvas to create a new ShapeNode. Set the ItemsSource property to an array or collection of shapes that should be rendered inside the control. For example, setting the Shape.Shapes list as ItemsSource will show all pre-defined shapes. You can customize the shape appearance by setting ShapeBrush and ShapeSize properties.
Shape formula improvements
  • The LocationForNode method of ShapeControlPoint returns current position of the control point for a node.
  • The UpdateShapeControlPoints method of ShapeNode lets you update the node appearance after adding new control points to a Shape.
  • ControlPoints are now saved in shape libraries.
  • Enable inertia for pan interactions by setting the PanInertia property to true.
  • A NodeRenderer added to custom node templates will now repaint automatically when any dependency property of the node changes.
  • Set FreeFormMode to enable free-form lasso selection that lets users draw irregular outline to select items inside.
  • HeadStrokeDashStyle property added to DiagramLink lets you set the dash style of arrowhead outlines independently from link segments' one.
  • Fixed orientation change gesture for cascading links when AllowSplitLinks is enabled.
  • PdfExporter now creates page hyperlinks if HyperLink is set to a value in "page://{number}" format, e.g. set "page://1" to open the second PDF page when the item is clicked.
  • Disable adding new headers to the lanes grid by setting AllowAddHeaders to false.
  • The new CustomTemplates sample project shows more elaborate Xaml templates applied to nodes.
  • The Visio Stencils import API provides access to BeginArrow and EndArrow values.
  • The Visio Stencils import API provides access to Connection elements defined for a shape.
  • Fixed bug in ResizeToFitText method with long words in the text when preserving node's ratio.
Updated assemblies are also available as MindFusion.Diagramming.Wpf NuGet package.
