Normal Topic Show outer labels in a pie chart? (Read 5111 times)
Dennis
Sep 14th, 2016 at 9:31am
Hi there,
I'm trying to create a pie chart with the JS library and I am having a problem how to show the outer labels.
I set them in the construcotr:
var series = new PieSeries(myValues, null, new Collections.List(["t1", "t2", "t3", "t4", "t5"]));
I have no errors, the pie shows but no labels. Is this a bug?
Re: Show outer labels in a pie chart?
Reply #1 - Sep 14th, 2016 at 2:25pm
The pie chart draws only inner labels by default. You can specify you want to show all label kinds supported by the series like this -
pieChart.showDataLabels = Charting.LabelKinds.All;
LabelKinds allows bitwise combination where you could enable / disable individual flags to show specific labels -
http://www.mindfusion.eu/onlinehelp/chart.javascript/index.htm?T_MindFusion_Char...
Dennis
Reply #2 - Sep 14th, 2016 at 7:11pm
The labels show now, thanks. Is there a way to increase the font size?
Reply #3 - Sep 15th, 2016 at 8:57am
There are various fontSize properties provided by the Theme class. For data labels set this -
pieChart.theme.dataLabelsFontSize = 12;
Here's a list of other Theme properties you could set for the chart -
