FlowChart.NET version 6.4.2 contains several customer-requested features and improvements -
Fluent APIExtension methods in MindFusion.Diagramming.Fluent and MindFusion.Diagramming.Layout.Fluent namespaces add support for fluent programming style:
using MindFusion.Diagramming.Fluent;
using MindFusion.Diagramming.Layout.Fluent;
diagram.Factory
.CreateShapeNode(10, 10, 20, 20)
.Brush(Color.LightGray)
.Font("Arial", 12)
.EnableStyledText(true)
.Text("Task <i>1</i>")
.ToolTip("This is the task");
new TreeLayout()
.LevelDistance(20)
.NodeDistance(20)
.LinkStyle(TreeLayoutLinkType.Cascading3)
.Arrange(diagram);
DiagramLink improvements~ the component no longer keeps a separate segmentCount field, removing a common source of errors. The SegmentCount property now calculates its value from ControlPoints elements. The UpdateFromPoints(updateGroups, updateSegments) overload has been removed too;
~ SegmentCount setter no longer refuses changing number of segments if auto-routing is enabled or the link is a self-loop;
~ the new Spline element of LinkShape enumeration draws links as interpolating splines that pass through all of their control points:
Miscellaneous~ the ModifierKeyAction.ExtendSelection mode selects items within the lasso without deselecting old ones;
~ the Visio Stencils import API provides access to BeginArrow and EndArrow values;
~ The Visio Stencils import API provides access to Connection elements defined for a shape;
~ it is now enough to set EnableStyledText to enable styled-text mode without having to also enable PolygonalTextLayout;
~ fixed bug where ItemAdded event wasn't raised for interactively drawn items;
~ miscellaneous UI control assemblies (NodeListView, LayerListView, Ruler, etc) have been merged into a single MindFusion.Diagramming.WinForms.Controls.dll;
If anyone is interested in trying the beta version, please download this archive containing updated assembly files:
https://mindfusion.eu/_beta/diagram.winforms.642.zipAny comments, questions and general feedback are welcome.
