Normal Topic Phone/Tablet style keyboard (Read 2872 times)
Dan Neely
Oct 18th, 2016 at 4:12pm
Can I have a more mobile style keyboard where the main layout is just alphabetic and symbols/numbers are on an alternate layout?
What about a combined shift/capslock (on long press) key?
Re: Phone/Tablet style keyboard
Reply #1 - Oct 19th, 2016 at 10:47am
There are no built-in layouts with separate alphabetic / numeric keys. You could create them yourself using the layout creator tool installed with the control, and load them as shown in the Layouts and Views samples. The Views sample happens to show separate text-only and number-only keyboards, depending on the type of entry field.
At this time you could detect a click on shift by handling the KeyPressed event, which is raised from mouse-down message handler, and detect the long press from a timer if the mouse hasn't moved since KeyPressed. If it's a long-press, you could toggle caps-lock by calling Key.CapsLock.Send().
