MindFusion
  MindFusion Xamarin Pack beta version includes diagram, chart and calendar controls for Xamarin.Forms. Now beta testing Chart and Gauge components for Java Swing.
  HomeHelpSearchLoginRegister
Diagramming for Windows Forms, V6.4.2
Read 868 times
Forum Admin   Offline
Gender: male
Oct 19th, 2016 at 10:57am
We have released version 6.4.2 of FlowChart.NET. It contains several customer-requested features and improvements:
Fluent API
Extension methods in MindFusion.Diagramming.Fluent and MindFusion.Diagramming.Layout.Fluent namespaces add support for fluent programming style:
Code:
using MindFusion.Diagramming.Fluent;
using MindFusion.Diagramming.Layout.Fluent;
diagram.Factory
	.CreateShapeNode(10, 10, 20, 20)
		.Brush(Color.LightGray)
		.Font("Arial", 12)
		.EnableStyledText(true)
		.Text("Task <i>1</i>")
		.ToolTip("This is the task");
new TreeLayout()
	.LevelDistance(20)
	.NodeDistance(20)
	.LinkStyle(TreeLayoutLinkType.Cascading3)
	.Arrange(diagram);
DiagramLink improvements
  • The component no longer keeps a separate segmentCount field, removing a common source of errors. The SegmentCount property now calculates its value from ControlPoints elements. The UpdateFromPoints(updateGroups, updateSegments) overload has been removed too.
  • SegmentCount setter no longer refuses changing number of segments if auto-routing is enabled or the link is a self-loop.
  • The new Spline element of LinkShape enumeration draws links as interpolating splines that pass through all of their control points:
  • the ModifierKeyAction.ExtendSelection mode selects items within the lasso without deselecting old ones.
  • the Visio Stencils import API provides access to BeginArrow and EndArrow values.
  • The Visio Stencils import API provides access to Connection elements defined for a shape.
  • It is now enough to set EnableStyledText to enable styled-text mode without having to also enable PolygonalTextLayout.
  • Fixed bug where ItemAdded event wasn't raised for interactively drawn items.
  • Miscellaneous UI control assemblies (NodeListView, LayerListView, Ruler, etc) have been merged into a single MindFusion.Diagramming.WinForms.Controls.dll.
http://www.mindfusion.eu/FCNetDemo.zip
Updated assemblies are also available as MindFusion.Diagramming NuGet package.
