Normal Topic Diagramming for Windows Forms, V6.4.2 (Read 3346 times)
Oct 19th, 2016 at 9:57am
We have released version 6.4.2 of FlowChart.NET. It contains several customer-requested features and improvements:
Fluent API
Extension methods in MindFusion.Diagramming.Fluent and MindFusion.Diagramming.Layout.Fluent namespaces add support for fluent programming style:
using MindFusion.Diagramming.Fluent;
using MindFusion.Diagramming.Layout.Fluent;
diagram.Factory
	.CreateShapeNode(10, 10, 20, 20)
		.Brush(Color.LightGray)
		.Font("Arial", 12)
		.EnableStyledText(true)
		.Text("Task <i>1</i>")
		.ToolTip("This is the task");
new TreeLayout()
	.LevelDistance(20)
	.NodeDistance(20)
	.LinkStyle(TreeLayoutLinkType.Cascading3)
	.Arrange(diagram);
DiagramLink improvements
  • The component no longer keeps a separate segmentCount field, removing a common source of errors. The SegmentCount property now calculates its value from ControlPoints elements. The UpdateFromPoints(updateGroups, updateSegments) overload has been removed too.
  • SegmentCount setter no longer refuses changing number of segments if auto-routing is enabled or the link is a self-loop.
  • The new Spline element of LinkShape enumeration draws links as interpolating splines that pass through all of their control points:
  • the ModifierKeyAction.ExtendSelection mode selects items within the lasso without deselecting old ones.
  • the Visio Stencils import API provides access to BeginArrow and EndArrow values.
  • The Visio Stencils import API provides access to Connection elements defined for a shape.
  • It is now enough to set EnableStyledText to enable styled-text mode without having to also enable PolygonalTextLayout.
  • Fixed bug where ItemAdded event wasn't raised for interactively drawn items.
  • Miscellaneous UI control assemblies (NodeListView, LayerListView, Ruler, etc) have been merged into a single MindFusion.Diagramming.WinForms.Controls.dll.
Updated assemblies are also available as MindFusion.Diagramming NuGet package.
