Normal Topic FBD - Function block diagram (Read 4117 times)
Heli
Oct 26th, 2016 at 1:38pm
how about a FBD - Function block diagram (https://en.wikipedia.org/wiki/Function_block_diagram) view type?
Would be handy to show left-to-right logic evaluations (AND/OR/XOR/...).
In step 2 maybe even other data types (int) and mathematical function blocks (+,-,*,/,Min,Max,Avg,...)?
Regards
HeliG
Re: FBD - Function block diagram
Reply #1 - Oct 26th, 2016 at 3:42pm
Thanks for suggestion. You should already be able to draw this using TableNodes for blocks and Transparent ShapeNodes for variables. We could probably add an auto-layout class specialized for that kind of diagrams if you'll be generating them from code-behind.
