Very Hot Topic (More than 25 Replies) How to create Lane node with text area/label and manipulate it (canvas mode)? (Read 18093 times)
CrushJelly
Oct 31st, 2016 at 2:14pm
I am making my own Swim lane node, the swim lane node should have editable with the vertical textArea/label.
I've created my own shape library with Shape that has text area, but
how do I edit this area?,
is there source code sample for this?,
do I need to use something different to create this text area?,
how can I adjust text angle?,
how can I make ShapeNode's text editable? (any node)
PS. I'm including image what it supposed to look like and where the text should go.
Re: How to create Lane node with text area/label and manipulate it (canvas mode)?
Reply #1 - Oct 31st, 2016 at 6:39pm
It looks like a rotated ContainerNode, check if this will work for you -
var ctr = diagram.Factory.CreateContainerNode(100, 0, 60, 200);
ctr.Caption = "Editable label";
ctr.RotationAngle = 270;
Note that the coordinates you pass to CreateContainerNode are for the non-rotated rectangle, and RotationAngle will rotate around its center.
You can edit by setting diagramView.AllowInplaceEdit = true and double-clicking. The text area does not match the rotated rectangle though; we'll fix it for upcoming release. Alternatively instead of double-click you could call Diagram.beginEdit method from a client-side event like NodeClickedScript.
Reply #2 - Nov 2nd, 2016 at 10:35am
This version of the script shows the edit box only over the caption-bar and considers node's rotation angle -
https://mindfusion.eu/_beta/jsdiag271.zip
If you find it too narrow that way, you can replace ContainerNode.prototype.getEditRect function with your own returning the edit box location and size you'd like to use -
ContainerNode.prototype.getEditRect =
    function() { return new MindFusion.Drawing.Rect(...); }
CrushJelly
Reply #3 - Nov 3rd, 2016 at 9:05am
Slavcho wrote on Oct 31st, 2016 at 6:39pm:
I created container node.
But EnableHandles doesn't work, I cant adjust containers size myself and some other properties didn't work to,
I'm including my code.
 var ctr = diagramView.Diagram.Factory.CreateContainerNode(100, 0, 60, 200);
            ctr.CaptionFormat = new StringFormat() { Alignment = StringAlignment.Center }; // Doesn't work
            ctr.Foldable = false;
            ctr.AutoGrow = false; // Doesn't work
            ctr.AutoShrink = false; // Doesn't work
            ctr.EnabledHandles = AdjustmentHandles.Move; // Doesn't work
Reply #4 - Nov 3rd, 2016 at 9:31am
By setting ctr.EnabledHandles = AdjustmentHandles.Move you only allow moving the node. Set ctr.EnabledHandles = AdjustmentHandles.All & ~AdjustmentHandles.Rotate to allow both moving and resizing.
CrushJelly
Reply #5 - Nov 3rd, 2016 at 9:39am
Slavcho wrote on Nov 3rd, 2016 at 9:31am:
Well still no effect...(including picture of selected container)
And what about Autogrow and Shrink, and Label alignment?
Reply #6 - Nov 3rd, 2016 at 12:06pm
Actually there's also the HandlesStyle property, with MoveOnly default value. Set it to another style and it should let you resize -
ctr.HandlesStyle = HandlesStyle.SquareHandles;
ctr.EnabledHandles = AdjustmentHandles.All;
Seems the AutoGrow/Shrink properties are not implemented in JS library, we'll try to add them soon. At this time you could call resizeToFitChildren method from client-side events to get similar effect.
CrushJelly
Reply #7 - Nov 7th, 2016 at 2:43pm
Slavcho wrote on Nov 3rd, 2016 at 12:06pm:
Ok, and how to adjust alignment of label?
I've set this property, but it's not working, the text stays at the bottom (like in prev ex.):
Reply #8 - Nov 8th, 2016 at 11:55am
CrushJelly
Reply #9 - Nov 15th, 2016 at 2:48pm
Slavcho wrote on Nov 8th, 2016 at 11:55am:
I try to add my custom ContainerNode to NodeListView, but when application runs there is no NodeListView, it disappears, when I turn on the browser console I see this error (see included pic.).
I checked my converter class, the serialization goes through perfectly, maybe I need to change my js class?
PS. When I prototype my custom container through ContainerNode constructor, everything works.
Reply #10 - Nov 15th, 2016 at 3:15pm
Any stack-trace for this exception? I can see "params" accessed as a field in Shape and ShapeRenderer classes, which are used only by ShapeNode but not ContainerNode. Maybe verify that the JavaScript class name you pass to DiagramView.RegisterItemType refers to ContainerNode-derived class and not ShapeNode one - you might get similar exception if JavaScript ShapeNode code tries to load a Shape instance, which would not be provided by server-side ContainerNode serializer.
CrushJelly
Reply #11 - Nov 15th, 2016 at 3:36pm
Slavcho wrote on Nov 15th, 2016 at 3:15pm:
Sorry my bad.  Embarrassed
After debugging, by mistake I spotted that I forgot to register the CustomContainer class in my JS file.
Now it works.
CrushJelly
Reply #12 - Nov 18th, 2016 at 7:33am
How to make container node Transparent?
I am now using:
 new MindFusion.Drawing.SolidBrush(Color.Transparent);
But my result is not what I expected.
Reply #13 - Nov 18th, 2016 at 9:18am
Set ShadowBrush to transparent too -
ctr.Brush = ctr.ShadowBrush = new MindFusion.Drawing.SolidBrush(Color.Transparent);
or disable shadows altogether -
diagram.ShadowsStyle = ShadowsStyle.None;
CrushJelly
Reply #14 - Nov 18th, 2016 at 9:37am
Slavcho wrote on Nov 18th, 2016 at 9:18am:
Cool, that works.
OK, then I got NodeListView problem, for some reason the ContainerNode box in the NodeListView appears bigger than other boxes and the whole visual view is messed up (see pic), I selected that node in the pic, the node above is normal looking.
Is there a way to fix this, or this is ContainerNode problem?
« Last Edit: Nov 28th, 2016 at 1:05pm by CrushJelly »
