Very Hot Topic (More than 25 Replies) How to create Lane node with text area/label and manipulate it (canvas mode)? (Read 18081 times)
Online
Re: How to create Lane node with text area/label and manipulate it (canvas mode)?
Reply #15 - Nov 18th, 2016 at 9:53am
I'm guessing the bounding box calculated for the node does not consider rotation. Our developer will check.
CrushJelly
Reply #16 - Nov 18th, 2016 at 12:41pm
Slavcho wrote on Nov 18th, 2016 at 9:53am:
Ok. Let me know if there is some fix or something. Smiley
Doe's the CaptionBrush should set the ContainerNodes caption box color?
Online
Reply #17 - Nov 18th, 2016 at 1:21pm
It's for the caption text color. In TableNode we have a CaptionBackBrush property for the background of captionbar but we haven't implemented it for containers; will try to add it there too for upcoming release.
CrushJelly
Reply #18 - Nov 28th, 2016 at 1:08pm
Slavcho wrote on Nov 18th, 2016 at 1:21pm:
I can't Align caption text at center, I tried these functions setTextAlignment and setLineAlignment, they are set to Center.
Is there workaround or I am doing something wrong?
Online
Reply #19 - Nov 28th, 2016 at 1:24pm
Have you replaced diagramming.js in your project with one from released version? If it still doesn't work, try clearing the browser cache.
CrushJelly
Reply #20 - Nov 28th, 2016 at 1:54pm
Slavcho wrote on Nov 28th, 2016 at 1:24pm:
Yes, I did. Cache is cleared. Still getting no result.
Online
Reply #21 - Nov 28th, 2016 at 5:05pm
By released version I mean v5.7 from last week, have you installed it?
http://mindfusion.eu/Forum/YaBB.pl?num=1480083513
Here's my test project, text alignments seems to work fine both from server and client sides -
https://mindfusion.eu/_samples/align_test.zip
CrushJelly
Reply #22 - Nov 29th, 2016 at 11:16am
Slavcho wrote on Nov 28th, 2016 at 5:05pm:
Can I make specific place clickable only?, where I can edit Container caption (ex. I need to click caption to edit it, not the whole container. If I click not the caption, it selects the container.).
How to limit or somehow wrap caption text? (see pic)
With the new version Behavior has reset. Previously the behavior was set to Custom and mouse drawing has stopped, but now when I installed new version it doesn't work, now on mouse interaction (drag) in the diagram it starts drawing nodes. How to get rid of this?
« Last Edit: Nov 30th, 2016 at 7:15am by CrushJelly »
Online
Reply #23 - Nov 30th, 2016 at 7:39am
You will have to disable AllowInplaceEdit and call Diagram.beginEdit when you detect click on caption -
function onNodeDoubleClicked(diagram, e)
	if (e.node.rotationAngle == 270 &&
		e.mousePosition.x < e.node.getRotatedBounds().x + e.node.captionHeight)
		diagram.beginEdit(e.node, e.mousePosition);
Online
Reply #24 - Nov 30th, 2016 at 9:26am
Text wraps at word boundaries. You could clip it like this -
ContainerNode.prototype.onUpdateVisuals = function (ctr)
	if (ctr.rotationAngle == 270)
		ctr.text.clipPath = new MindFusion.Drawing.Path();
		var cr = ctr.bounds;
		ctr.text.clipPath.addRect(cr.x, cr.y, cr.width, ctr.captionHeight);
You could implement your own wrapping function that measures separate characters instead of words if you think it's necessary (case from your image looks more like users fooling around instead of writing useful text  Wink) E.g. see http://mindfusion.eu/Forum/YaBB.pl?num=1415114615/3#3 for the overriding code (not actual character measuring).
Custom behavior means it will draw the item types specified in CustomNodeType and CustomLinkType. If you want to prevent drawing, set Behavior to DoNothing, Modify or SelectOnly.
Online
Reply #25 - Dec 6th, 2016 at 7:03pm
This version adds ContainerNode.CaptionBackBrush property -
https://mindfusion.eu/_temp/netdiag_captionbrush.zip
