Normal Topic Manipulating nodes at runtime programatically (Read 3343 times)
Gravity
Nov 16th, 2016 at 3:56pm
I am loading xml through this method "diagramView.LoadFromString(string ..".
In what property current xml is loaded?
Can i manipulate it pragmatically?
I tries inspect that DiagramView object, but could not find obviously : )
Gravity
Re: Manipulating nodes at runtime programatically
Reply #1 - Nov 16th, 2016 at 4:00pm
Ok. I apparently overlooked : ) it is in the Diagram property of DiagramView.
_diagramView.Diagram.Nodes daah
Online
Reply #2 - Nov 16th, 2016 at 4:21pm
Hi!
The xml string is the result you'd get from previous call to SaveToXml / SaveToString, or are you generating XML in diagram's format dynamically? Anything you can do interactively can also be done programmatically using the control's public API - creating nodes and links, setting their positions, etc.
Gravity
Reply #3 - Nov 16th, 2016 at 5:43pm
Yes i understand that : ) at first i just overlooked, and thought that it would be just faster if asked, sorry for that : )
Cheers mate Smiley
