Normal Topic Version 3.4.2 beta (Read 2435 times)
Version 3.4.2 beta
Nov 28th, 2016 at 9:09am
Version 3.4.2 of WPF Diagram control contains the following new features and improvements -
Fluent API
Extension methods in MindFusion.Diagramming.Fluent and MindFusion.Diagramming.Layout.Fluent namespaces add support for fluent programming style:
using MindFusion.Diagramming.Wpf.Fluent;
using MindFusion.Diagramming.Wpf.Layout.Fluent;
diagram.Factory
	.CreateShapeNode(20, 20, 60, 40)
		.Brush(Colors.LightGray)
		.Font("Arial", 12)
		.EnableStyledText(true)
		.Text("Task <i>1</i>")
		.TextRotationAngle(15);
new TreeLayout()
	.LevelDistance(20)
	.NodeDistance(20)
	.LinkStyle(TreeLayoutLinkType.Cascading3)
	.Arrange(diagram);
DiagramLink improvements
  • The component no longer keeps a separate segmentCount field, removing a common source of errors. The SegmentCount property now calculates its value from ControlPoints elements. The UpdateFromPoints(updateGroups, updateSegments) overload has been removed too.
  • SegmentCount setter no longer refuses changing number of segments if auto-routing is enabled or the link is a self-loop.
  • The new Spline element of LinkShape enumeration draws links as interpolating splines that pass through all of their control points:
  • The RotationStep property of Diagram class specifies the increments applied to a node's RotationAngle during interactive rotation.
  • The Bounds property of DiagramNode now supports binding.
  • GridRouter evaluates routes between more remote sides of connected nodes when RoutingOptions.EvaluateFarPoints is enabled.
  • Fix for magnifier offset when origin of Diagram.Bounds is non-zero.
If anyone is interested in trying the beta version, please download this archive containing updated assembly files:
https://mindfusion.eu/_beta/wpfdiag342.zip
Kim Lillås
Re: Version 3.4.2 beta
Reply #1 - Nov 29th, 2016 at 8:55am
Thanks for the information.
Did I understand you correctly in that RoutingOptions.EvaluateFarPoints = true will evaluate the routing for several node anchor points?
//Kim
Reply #2 - Nov 29th, 2016 at 9:00am
Yes, it will evaluate points from all sides as long as RoutingOptions.Anchoring != Keep; seems we added this for you couple of weeks ago -
http://mindfusion.eu/Forum/YaBB.pl?num=1478691586/6#6
