Normal Topic Add Diagram to Pages of DiagramDocument ? (Read 1764 times)
eXTruDEr
Mind con Fusion ;-)
Dec 5th, 2016 at 10:37am
is it possible to add a Diagram to a DiagramDocument?
In my code Diagrams can be created dynamically. If wanted they should be grouped later. These diagrams are then to be written in a common PDF. According to the documentation, DiagramDocuments can be exported as PDF as well as a single Diagram.
Re: Add Diagram to Pages of DiagramDocument ?
Reply #1 - Dec 5th, 2016 at 12:42pm
You can only add a DiagramPage to document.Pages. The DiagramPage class inherits from Diagram, so you could use same code to populate it if generating diagrams dynamically. If you let your users draw diagrams interactively, you could use SaveToString/LoadFromString methods to transfer Diagram contents to a DiagramPage.
eXTruDEr
Mind con Fusion ;-)
Reply #2 - Dec 5th, 2016 at 1:07pm
thx 4 reply. Smiley
I found a simple solution for my problem: I just create DiagramPages instead of Diagrams.
Diagram dia = new Diagram(); => DiagramPage dia = new DiagramPage();
