Normal Topic How to override base custom behavior (canvas mode)? (Read 3922 times)
CrushJelly
Dec 8th, 2016 at 8:41am
Hey, so there is my question:
Can I override base custom behavior?, because in the Silverlight there is property CustomBehavior, but in the WebForms, there is no such property.
If it is not possible to override, then how can I make disabled node resizing, just selection and drawLinks?
« Last Edit: Dec 8th, 2016 at 10:14am by CrushJelly »
Re: How to override base custom behavior (canvas mode)?
Reply #1 - Dec 8th, 2016 at 10:31am
The standard Behavior.DrawLinks lets you select existing items and draw new links. You can disable resizing by setting nodes' EnabledHandles property to AdjustmentHandles.Move value, or by setting their HandlesStyle property to HandlesStyle.MoveOnly.
If you are still using custom link types, you will also need to replace this factory function with one creating your link class instances -
DrawLinksBehavior.prototype.createLink = function (origin, point)
	var link = new mdiag.DiagramLink(this.diagram, origin, point);
	link.originConnection.chooseBestAnchorPoint(point);
	return link;
You could as well create a complete class derived from BehaviorBase. There's not CustomBehavior public API declared as in Silverlight version, but you can still assign your instance to the Diagram.currentBehavior field.
CrushJelly
Reply #2 - Dec 8th, 2016 at 11:11am
Slavcho wrote on Dec 8th, 2016 at 10:31am:
	return link;
Can I set Handles color and how can I change Anchor Mark size?
Reply #3 - Dec 8th, 2016 at 1:55pm
You can assign handles color to diagram.handleBrush from client code. You can specify mark size through AnchorPoint constructor; if you need to change it for a pre-defined pattern, loop over its points array and call AnchorPoint.setSize.
