MindFusion
  Version 2 of our Xamarin Calendar component adds Resource view and support for Universal Windows Platform. Now beta testing spreadsheet component for Java Swing.
  HomeHelpSearchLoginRegister
Can I set the template and style in xaml instead of code behind
Read 301 times
Dan Neely   Offline
Dec 19th, 2016 at 7:06pm
Your example code all shows these being set in code behind; which means that the UI designer always shows your default layout instead of the layout I'm using.
ex from StyleSamples.cs in your example projects:
Code (C++):
virtualKeyboard.TemplateLayout = KeyboardLayout.Create(
                    this.GetType().Assembly.GetManifestResourceStream("Styles.CustomLayout.xml"));
//set custom style of VirtualKeyboardStyle from file
resources.Source = new Uri("/Styles;component/VirtualKeyboardWithImages.xaml", UriKind.Relative);
this.Resources.MergedDictionaries.Add(resources);
Slavcho   Offline
Gender: male
Re: Can I set the template and style in xaml instead of code behind
Reply #1 - Dec 20th, 2016 at 4:08pm
You can define keyboard layout from Xaml like this -
Code:
<vk:VirtualKeyboard>
	<vk:VirtualKeyboard.TemplateLayout>
		<vk:KeyboardLayout>
			<vk:KeyboardLayout.Keys>
				<vk:RegularKey Content="A" Left="10" Top="10" Width="60" Height="60" />
				<vk:RegularKey Content="B" Left="80" Top="10" Width="60" Height="60" />
			</vk:KeyboardLayout.Keys>
		</vk:KeyboardLayout>
	</vk:VirtualKeyboard.TemplateLayout>
</vk:VirtualKeyboard>
Seeing an external layout file created using the Keyboard Creator tool in VS design time should be possible too - try creating an IValueConverter that returns KeyboardLayout.Create(filename) from Convert method and use it in TemplateLayout binding expression.
