Normal Topic Pop Up Details (Read 3468 times)
dolfandon
Pop Up Details
Jan 11th, 2017 at 7:47pm
Is there an example of how to display a modal popup with information about the double clicked node? I figured out how to get the node information but I can't get a popup to work on a page with the diagram control on it. Thanks.
Re: Pop Up Details
Reply #1 - Jan 12th, 2017 at 9:39am
You probably need to convert from diagram coordinates to page ones. Try something like this, converting from MeasureUnit to pixels and adding the diagram's canvas offset in page -
function nodeDoubleClicked(sender, args)
        var rect = args.getNode().getBounds();
        var p = sender.docToClient(rect.topLeft());
        var controlPos = $(sender.get_element()).offset();
        $('#win').css('left', p.x + controlPos.left);
        $('#win').css('top', p.y + controlPos.top);
        $('#win').modal('show');
dolfandon
Re: Pop Up Details
Reply #2 - Jan 12th, 2017 at 4:55pm
I'm assuming that thee should be a div with the id on win for this to work. Unfortunately it still didn't work for me. Do you have an example of a pop up on a diagram control?
Re: Pop Up Details
Reply #3 - Jan 13th, 2017 at 7:52am
You can find an example here, draw a node and double click to see the pop-up aligned with the node -
https://mindfusion.eu/_samples/popup_test.zip
