MindFusion
  Version 2 of our Xamarin Calendar component adds Resource view and support for Universal Windows Platform. Now beta testing spreadsheet component for Java Swing.
  HomeHelpSearchLoginRegister
Pop Up Details
Read 365 times
dolfandon   Offline
Gender: male
Northern Virginia
Pop Up Details
Jan 11th, 2017 at 7:47pm
Is there an example of how to display a modal popup with information about the double clicked node? I figured out how to get the node information but I can't get a popup to work on a page with the diagram control on it. Thanks.
Slavcho   Offline
Gender: male
Re: Pop Up Details
Reply #1 - Jan 12th, 2017 at 9:39am
You probably need to convert from diagram coordinates to page ones. Try something like this, converting from MeasureUnit to pixels and adding the diagram's canvas offset in page -
Code:
function nodeDoubleClicked(sender, args)
        var rect = args.getNode().getBounds();
        var p = sender.docToClient(rect.topLeft());
        var controlPos = $(sender.get_element()).offset();
        $('#win').css('left', p.x + controlPos.left);
        $('#win').css('top', p.y + controlPos.top);
        $('#win').modal('show');
dolfandon   Offline
Gender: male
Northern Virginia
Re: Pop Up Details
Reply #2 - Jan 12th, 2017 at 4:55pm
I'm assuming that thee should be a div with the id on win for this to work. Unfortunately it still didn't work for me. Do you have an example of a pop up on a diagram control?
Slavcho   Offline
Gender: male
Re: Pop Up Details
Reply #3 - Jan 13th, 2017 at 7:52am
You can find an example here, draw a node and double click to see the pop-up aligned with the node -
http://mindfusion.eu/_samples/popup_test.zip
