Hot Topic (More than 10 Replies) Exception in LoadFromStream when strong named key file changed (Read 10613 times)
Re: Exception in LoadFromStream when strong named key file changed
Reply #15 - Feb 13th, 2017 at 7:09am
Based on answers from http://stackoverflow.com/questions/5794686/serializationbinder-with-listt, this fixed the Dictionary<string, MyTag> exception for me -
public override Type BindToType(string assemblyName, string typeName)
	if (assemblyName.StartsWith(Assembly.GetExecutingAssembly().GetName().Name))
		return Assembly.GetExecutingAssembly().GetType(typeName);
	if (typeName.Contains("[["))
		return Type.GetType(StripAsmStrongName(typeName));
	return null;
string StripAsmStrongName(string genericTypeName)
	while (true)
		int index1 = genericTypeName.IndexOf(", Version");
		if (index1 == -1)
			return genericTypeName;
		int index2 = index1 + genericTypeName.Substring(index1).IndexOf("]");
		genericTypeName = genericTypeName.Remove(index1, index2 - index1);
David Long
Reply #16 - Feb 15th, 2017 at 10:16pm
Sorry for delay, I did not see the second page of postings (the page numbers are very small or maybe I need new glasses!)
Your solution works perfectly Smiley Many thanks - with the right search terms StackOverflow often comes up with the answer. I don't think I searched for the right thing.
Thanks again,
DavidL
